cab and chassis
  1. C
    Shore Power suggestions, DIY. Multi-circuit 120v 20-30 amps.
    I have a 2012 Cab and Chassis (5.7L) with a early 2000's 9' utility body. The time is near to upgrade the toolbox, and I'd like to make my own Shore power setup for the following applications: - Block heater on a programable thermostat/timer (suggestions encouraged). Perhaps Shore Power >...
  2. 1
    1st Gen Cab Mounts
    Hello everyone. I'm new to the page and have a 1987 Dodge D250 I am currently trying to replace my front cab mounts. I'm curious if anyone here has bought these cab mounts and installed them? The rear ones are okay but the front ones rusted through. Or if anyone has any other parts/ways they...
  3. F
    2006 Cab Swap onto a 2007.5 Frame and Powertrain
    Hey everyone, First time posting on a forum like this, I’ll attempt to give as much info as possible. My situation is that I have a rolled 2007.5 6.7 l dodge 2500 crew cab which the cab and box are pretty much done. I was however able to find a 2006 2500 crew cab, which is largely the same. It...
  4. C
    P0087,P020B codes
    My 2012 5500 has just started throwing the same codes P0087 my mini max says it’s fuel rail/system pressure too low, and it’s throwing P020B fuel injector 2 performance and throws that code for injectors 2,3,4,5, what would cause it all the codes to come up all at once. If some one could help...
