clunking sound
  1. D
    Aftermarket air ride (air ride 5000) concerns.
    Is it normal for there to be a gap between the truck and the bottom plate of the air bags? The plate has 2 hook brackets on one side and carriage bolts on the other but with my truck sitting on Jack's, there is a sizeable gap between the 2. Im looking for a clunking noise that has been coming...
  2. 4G907
    2013 1500 5.7 - Shutters at 5mph coming to Stop and when letting go from a stop. Occasional Clunk...
    Hello, I have a 2013 Ram 1500 4X4 Laramie and I am having a weird braking issue. A year ago when I got the truck, I noticed a few months after, when I came to a stop there is a *clunk* noise coming from the rear. Thought it was my 3 ton jack in the back hitting the front of the bed, but it...
  3. P
    Brake clunking help
    Hello all, I’ve got a 2019 Ram 1500 Classic Big Horn with about 35.5k miles. No issues when just starting a drive in the morning but after about 30+ miles of driving from work my brakes make a weird clunking noise when i press them down while at slow speeds or if I’m stopped (parking lots, my...
  4. C
    Sway when driving 98.5 24v 4wd stock.
    I have been trying to figure this issue out for a little over a month, and am completely stumped. Hoping someone has had this issue. When I drive my truck over 45 miles an hour it begins to sway pretty badly to the left and right. Similar to sway as though you were pulling a trailer with no...
  5. L
    Loud Clunk!!!!
    I have a new problem for me. It has only happened twice and both times at a steady speed, no bumps, no acceleration, no turns, one time at 75mph, the other at 40mph, but a loud clunk in what sounds like the driver side rear of my truck. Both times I heard it, I thought I had run over a block of...
  6. T
    Mystery Front End Clunk...
    I'll try to give you the details without going crazy here... There is a TL;DR at the end. I know this is a novel at this point, but my stress and frustration are high enough that I'd rather y'all have all the details than be missing anything I didn't mention. For all I know, I'm overlooking...
  7. Larry Waters
    Strange clunking sound in the front end
    Strange clunking sound in the front and I have a sound it lightlyReverberates through the steering wheel. I notice it’s more prevalent obviously a bumpy road it almost sounds like a loose shock tower bolt. I took it to a non-ram shop they replace the tire rod ends wheel bearings steering bar...
totalsistem
