emergency brake
  1. P
    Parking/Emergency Brake Issue
    Last night I was parked on my driveway and after putting the parking brake on, I went to go leave and pulled the lever. The pedal came back a little bit but the light was still on. After some investigation, I found that I had to pull the lever and also pull the pedal back further so that it...
  2. dlad
    Emergency brake light
    When first started my emergency brake light turns on as the vechile goes through it function check than turns off all normal there. The problem comes when I apply the e brake the brake applies as normal but the indicator light never comes on. Any suggestion would be helpful thanks
ChrisOttsWSJ
