fuel sensor fail
  1. A
    Fuel Level Sender fail after filter change
    So is it a really strange coincidence or could it be a cause? Changed fuel filters as well as oil and air. Upon restart I get a fuel sensor error and gauge doesn't work. During this time I also put the spare back in its mount. Was off due to tail ight not getting power and I had to run a...
  2. L
    Fuel sensor fail faulty sending unit photos
    I just changed my fuel pump and sending unit and thought I would share some pictures most common failure on oem units The wiper puts too much pressure on the mica plate and rubs the contacts right off also oem does not use a hard enough plating on contacts best bet is to buy aftermarket...
