#help
  1. P
    Fuel Tank
    Is part "Fuel Tank - Mopar (68323675AC) - 26 Gallon Tank" a direct replacement? Like i do not need to add anything if nothing else is damage I.E. Pump, brackets Etc. I have having filling issues and we have replaced everything except the tank now. Which is my next step. Also if i upgraded to...
  2. A
    Truck trouble clicking at the starter but no crank
    My truck won’t start I have tried about everything. My relay wheels and I have used wire instead of the relay. My starter gets 12 volts til I crank then it gets 7.5 volts.
  3. F
    Alpha obd can’t change mileage
    Hey everyone I upgraded my cluster to the 7” and having issue changing my odometer mileage, I’m using alpha obd with a Mx connector and manage to change my driving hours and idle hours but my odometer isn’t changing , anyone else have this issue if so what did you do to fix it thx
  4. J
    how much oil do i have to use?
    so before i start i wanna apologize for my english.i need your help, my dad gave me the task to find out how much oil we have to put in the car.i searched so many websites but i could just find the answer for the engine oil.the year the car was built is 2014 and it is a 5,7 L.I´ts an automatic...
  5. G
    Will it fit?
    I have an 02 1500, and i was wandering how easy/ difficult it would be to swap my crapped out blown 4.7, for a not so crapped out not so blown 5.9 of the same gen. And if it would mate to the same trans that was hooked up to the 4.7. Thanks in advance.
jimn
