interior lights
  1. J
    Bench seat wire harness
    I am trying to find a harness to tap in to for floor lights on my 2018. I found this wire harness under the flooring under the bench seat in the rear on the passenger side. I check for power but there's no power going to it. Does anybody know what this connector is for and where I could find a...
  2. Kellce61
    Interior Lights work intermittently
    I have a 21 1500 Classic crew cab that I purchased used last summer and love it. Shortly after buying it we noticed the back cab light worked intermittently. Had it at the dealer for some maintenance and they said it had an LED build and shouldn't have, so they replaced with and incandescent...
  3. 3500 lifted Mega
    Led lights in Speedo Cluster
    I'm having issues with my speedo cluster. The entire cluster works fine I just have 2 or 3 leds inside the cluster that have burned out. Dodge wants to sell me a whole cluster ..which is overkill. Anyone else have this issue ? I know bulbs need to be soldered but cant get any other info. thanks
  4. pavementprincess
    Instrument/Gauge/Odometer Cluster - 02 1500
    I've researched this a little online, and seen similar issues on other Dodge Rams and other brand (i.e. Ford) trucks: my Odometer light on my instrument cluster fades in/out, and has been getting progressively worse. Its to the point where the Odometer light on my cluster is out for a week or...
  5. Socalramfan
    Anybody know what this was intended for?
    Just completed a Full Console swap in my 2011 Quad Cab, love the look and storage options. Had to get a new center Radio bezel, (lucked out... got one of only two new ones in the US, but took a while to locate), upon receiving it I noticed on the bottom of the bezel there is what appears to be...
  6. 14Fiveseven
    Interior Ambiet Lighting for Ram Sport
    I have a 2014 Ram 1500 Sport and I believe its called ambiet lights (lights that are by where your feet go). From what i can see its a total of 4 lights. 2 in the front and 2 in the rear which are under the seats. I want to change those to leds. Dont like the yellow look since I changed all the...
brixten
