jake brake
  1. Breck Barton
    Antifreeze can’t keep it in the revisor
    Sunday I put new coolant tank in 2015 ram 6.7 turbo. Got it in just took time. While installing I got air in system. And I also didn’t have one of the 2 lines the go in the top of tank loose . So I lost fluid them but figured the lose hoes was it. Tighten clamp up bled the system called it a...
  2. D
    Engine Brake: Suggestions..?
    Hi Ram People, A friend of mine has a Gen2 Ram diesel which came installed with a genuine Jacobs Compression Brake (i.e. 'Jake Brake'). Dodge say that part is now discontinued, even if I wanted to get it from them. A Google search brought up the PacBrake, which appears to be essentially the...
joshhhh
