motor rebuild
  1. midnight express
    Rebuilding 5.7 hemi
    My piston sleeve dropped a little so I’m wondering what would be the best choice. To rebuild the engine from lifter piston heads cam shaft gaskets timing chain. Or should I just try an get a used or complete rebuilt engine an what years can I put in a 2014 ram 1500 express classic
  2. G
    Rebuilt hemi backfiring through intake
    I have a 2006 ram 1500 mega cab with the 5.7 hemi with no EGR. I bought a junk yard motor and took it to be rebuilt at a machine shop. After I installed it I tried to start it but problem is that it wouldn’t. I checked spark and fuel. Both were good. I checked compression and all cylinders had...
  3. MrFixIt
    03 SiL Project
    Issue: Won't idle and is running lean with new fuel pump and motor overhaul. Cold start will run for 3-5 min, if rev'ed or loaded more than placing into gear motor stalls. Won't drive, barely idles at 550RPM, then stalls. Background: swapped trucks with Son-in-Law because the 2003 Dodge Ram...
Stu1104
