Rebuilding 5.7 hemi
midnight express
Pennsylvania
My piston sleeve dropped a little so I’m wondering what would be the best choice. To rebuild the engine from lifter piston heads cam shaft gaskets timing chain. Or should I just try an get a used or complete rebuilt engine an what years can I put in a 2014 ram 1500 express classic
tron67j
Maryland
There are a lot of threads on this forum about rebuilding engines as well as buying used or remanufactured engines. I recommend doing a search and reading through those. You will get some good information and can maybe connect with people who have had to make similar decisions.
Good luck.
Daw14
South Florida
Your piston sleeve dropped ?
Could you please explain how you made this decision?
Do you have pictures to share with the forum ? They might be of interest to some.
How many miles on the engine ?
How many on truck ?
How long ago was the engine rebuilt, or was it just one cylinder that needed sleeved ?
Sherman Bird
Houston, Texas
How many on truck ?
Wake up! It's word salad!:bleh:
midnight express
midnight express
Pennsylvania
The mechanic said it was just the one that slipped down a little. On the bank 2 side. I do not have pictures currently but I can probably get some. I bought the truck used it currently has 172,000 miles on it. I am going to be calling him today and making sure that he has the proper tools to do the work an the engine is the original engine and I don’t know what the prior owner did with the truck. Do have the carfax on it though an it is just one cylinder that needs it.
