motor swap
  1. R
    318 swap from a 360 wiring help
    Hey, I’m about halfway through putting a 318 into a 94 ram 1500 and I’m running into some wiring issues, the original motor was a 360 and the 318 I believe is from a 92 Dakota but that’s what I found from typing in some part numbers. But I was just wondering if anyone has done this swap before...
  2. R
    2005 Dodge Ram 1500 4x4 4.7L to crate 5.7L swap
    Looking to see if it has been done list of thing I need I know motor, and all supporting parts for the 5.7L alternator, power steering pump, A/C compressor, motor mounts,full exhaust, computer, wiring harness. My question is what am I not thinking any adapters I have to get for the trans or will...
  3. Richard Reed
    95 motor in a 96 problems
    My father has a 96 that's been down for awhile. He LKQd a 95 motor and swapped it in. Everything was good, but all in all it won't fire. The only code that comes up when you do the turn key check is CPS sensor. We've replaced it 3 times and changed out the PCM and still no luck. Any ideas or...
