nerf bars step bars running boards
  1. rubes7202
    Nerf Step Bars-2015 RAM Crew Cab - $100
    These are in great condition and come with brackets attached. They came off my 2015 RAM 1500 Crew Cab. I don't remember the brand because i purchase and had them installed at an aftermarket spot in Hayward. They cost me about $800 installed 4 years ago. They are 7 feet long and 4 inches in width.
  2. T
    Another Nerf Bar Question
    Looking to add a set of nerf bars to my Quad Cab. Been checking out the hoop style by N-Fab and the rock rail style by Tyger Star Armor. Leaning towards the Tyger because EVERYBODY has the hoop style. Anybody got advise on which way to go? Anybody using either of these? Thanks for any feed...
  3. OEDRO
    6 Inch Wide Running Boards for Dodge Ram 1500 / 2500 / 3500 Crew Cab
    OEDRO Running Boards for 2009-2018 Dodge Ram 1500 Crew Cab & 2010-2018 Dodge Ram 2500 / 3500 Crew Cab | Textured Side Steps | Nerf Bars 6 Inch, wider. Shop Now $20 OFF ☆ PROMO CODE:20COUPONSTEP Secure, slip-proof steps that protect your Jeep from getting hung up on obstacles while...
  4. OEDRO
    4 inch running boards or 6 inch running boards?
    Which one will you choose? 4 inch running boards or 6 inch running boards? No matter what you choose, take a look OEDRO running boards. Features: Quality materials with 3 different layers: carbon steel layer, electro-galvanized “e-coat” layer and the final powder coat later. Laser measured for...
  5. OEDRO
    [3 Layers] 4 Inch Running Boards starts at $129.99
    OEDRO’s running boards use the latest technology to protect your Dodge Ram while offering the support you need. Made with all-in-one heavy duty steel tubes that offer the best in durability, corrosion protection, and strength. Secure, slip-proof steps that protect your Jeep from getting hung...
  6. M
    2019 Megacab 2500 Nerf Bars?
    Anyone know of any Nerf bars that fit a 2019 2500 Megacab Cummins? Not looking for the step tubes, I would like the drop step nerf bars. Westin said they do not make them for the Megacab.
  7. Eddywardo
    Need help installing some OEM step bars
    I’m having trouble bolting up some nerf bars that I bought used. Both trucks are crew cabs, same generation so I assumed they’d be plug and play. In the picture I was only able to bolt up the bottom two holes but the top ones have no thread to screw the bolts. This is only in the back/cabin...
