rear pinion
  1. B
    Rear pinion seal replacement/ socket sizes
    The rear pinion seal is not difficult, although I had a hard time finding the pinion bolt socket size before getting into the project. So here is what I had. Drive shaft bolts are 15mm Pinion bolt is 1 1/4” I have a 2011, 1500 sport that had the rear end recall. I wasn’t expecting to run into...
