sound system
  1. expressreg
    Door panel tweeters
    So i got some door panel tweeters OEM from a 2023 limited longhorn Ram i have 2017 Ram Rt, i wanted to ask if anyone has done the wiring for this or could tell me what to tap in to The connector pics is the factory harness from the 2023 limited longhorn Ram that plugged into the tweeters
  2. DongLeeH
    2nd Gen Steering Wheel Audio Controls
    Hello, I was curious if anyone has a 2nd gen dodge that came factory with audio SWC? Pinouts do mention an audio control pin on the clockspring, with my 96 missing one on the vehicle side. I have seen pictures of the later 98+ trucks with audio SWC, but with the earlier clockspring missing a...
  3. RAM_36
    Ram 1500 Factory Audio System
    I was wondering if anyone knew what the factory audio system specifications are for the 2016 ram 1500 tradesman. And i was wondering if anyone had any suggestions on aftermarket sound systems. Thanks!
  4. expressreg
    Amp problem
    So recently or more like a year now my truck been disconnecting the audio i had the base model radio before i upgraded to the 9inch android screen and from there it started to disconnect and when i put my stock radio back on it still did it but not as often. my truck came with a full set of...
  5. T
    Sound System. Please Help!!
    Hello everyone new here. I have a problem and was hoping if anyone can help me out please. Heres some background knowledge to help understand more. I recently turned 18 and was gifted a beautiful ram 1500 2016 ecodiesel from my dad. The very first thing i did was spend money to get a system in...
  6. B
    Add sub to '06 Infinity sound system?
    I read that the stock Infinity amp is an 8 channel, leaving one open channel... Does anyone know if there's a way to connect to this channel and run it to another amp (either using a LOC or a sub with high level inputs) so I can add a sub without having to replace the factory radio or tap into...
  7. K
    2002 ram 1500 5.9
    hello! THIS SYSTEM HAS ALOT OF POTENTAL! i know ive messed up in places i cant even think, this is my first build! so im going to try to give all the info so you wont have any questions... hopefully, im going to do my best to remember specific watts ect. ive got a 2002 ram 1500. i've installed a...
