towing wiring
  1. D
    New 2022 2500 Laramie with 5th wheel package. No 4 pin connector on bumper.
    Disregard - 12 pin is for surround camera system. Just picked up the truck today. It has a 7 pin connector and a 12 pin connector (same as in the bed) on the bumper, but no 4 pin connector anywhere. I’ve seen you tube videos with the same setup, but don’t have a clue why you would want a 5th...
  2. C
    Reverse lights stuck on
    I have a 2010 dodge ram 1500, 5.7 Hemi, and automatic transmission. Also tow package and both 7 pin and 4 pin connections, (Read on to see why I'm including tow info). About a year ago the reverse lights started occasionally staying on. I would disconnect the battery for a bit then reconnect it...
rockyj69
