transmissikn issues
  1. stinkfinger
    NEED HELP ASAP
    Guys, I am in a pinch here and need some help. The other day I went into limp mode and made it home, I got the service trans error message. I did some digging and noticed that fuse # F57 was Blown so naturally I replaced it and started it back up and it drove good for a few miles. so i parked it...
  2. R
    2005 Ram 2500 Hemi 5.7 Goes to neutral at low speed
    I am having a issue with my Ram 2500 4x4 where when accelerating from a rolling stop the trucks trans seams to slip like in neutral. I come to rolling stop and then hit gas. The truck goes through 1st gear then when it should go to 2nd it slips. If I step on gas more nothing happens. If I...
  3. I
    Help Please 2009 Dodge 1500 4.7
    I swapped engine and tranny from a wrecked Donor truck that had low miles into my high miles engine knocking 2009 Dodge 1500 automatic 4.7. Truck cranked right up everything worked until I drop it in Drive it has no power almost acts like it is in high gear trying to take off and engine appears...
  4. Badcom
    96 ram 1500 tranny issues ( has 97 tranny )
    So, I have a 96 dodge ram 1500 5.2 2wd. While back had issues where the truck would stall going Into first gear. Then, when it would run, I would get to about 45-55 mph, would feel like the engine was going to jump out from under the hood. I replaced the governor pressure sensor, and another...
joshhhh
