transmission cooler
  1. E
    2015 ram3500 6.4L transmission issues
    Hello need some help on trying to figure out what’s causing my transmission to drop to first gear transmission sounds right no grinding or any other noises. The first 15 min truck runs fine then when oil get normal temp it drops then I let it cool off for 5 min and it does it agin. I already...
  2. S
    Transmission woes
    My transmission started to slip badly, so I turned around and limped it back home. Upon inspection, I found the transmission cooler line had ruptured and transmission fluid was leaking. I repaired the transmission lines, and refilled the transmission with new transmission fluid. (I followed...
  3. R
    Transmission Fluid Temperature
    Got a 2017 RAM 1500 SLT (Quad/4x4/Pentastar) about a month ago now. Been doing some work to it little by little on the weekends, and one thing I'm paying attention to now is the temps. Right now it's 80% humidity and in 84 degrees F ambient temperature, I noticed the transmission fluid temp...
  4. Grandpa Sleeper
    Transmission heat sensor problems
    Hey guys I've got a question about my edge juice with attitude on the ole 2nd gen grandpa truck. I go into the menu and there are two different transmission temp readings, TFT (trans fluid temp) and JTFT (juice trans fluid temp) the JTFT generally reads about 30 degrees cooler than the TFT which...
  5. Intense-Dakota
    First long haul w/ 4K lb - Engine/Trans Braking in mountains?
    I have had many trucks through the years, and about 6 months ago I replaced my 2014 2500 with a 2017 REBEL (5.7L, 8 speed, 3.92 4x4, CC, Air Suspension). I have towed a lot, but all usually within 20-30 miles, and never through the mountains. I have driving Pike's Peak and Mt. Washington so I am...
jimn
