usb outlet
  1. Challengersky
    USB console hub power
    I have a 2022 RAM Limited 1500 eTorque. I use a Nexar camera and it needs to be connected to ignition controlled power. Unfortunately my truck doesn't have any ignition controlled power outlets, they are all 'always' active. My fuse boxed doesn't have the dual position fuses like older RAMs...
  2. continuecrushing
    How-To: Add USB Charger Outlet in Rear Doors
    Adding USB chargers or cigarette lighter outlets in the back of your truck is pretty easy! What you'll need: Amazon" USB outlet/charger...get 2 if you want to do both sides Amazon: 1 1/8 hole saw Amazon: T15 screwdriver Amazon: Wire Strippers Amazon: Multimeter You'll first remove the rear...
