wire routing
  1. SugaryClapz
    Need help with wiring!
    I’m trying to wire up a drl with 2 wires going to a connector in the fuse box but one wire is too short. How do I splice the shorter wire to the longer one so they both are connected? Pic 1: longer wire Pic 2: short wire
  2. S
    Where to route cable for power inverter from battery to inside Ram 1500 cab?
    Hi All, I just purchased a 1000 watt power inverter to charge my drone batteries on the road as the DC plug on the dash doesn’t proved enough wattage. I’m looking to have the inverter underneath the passenger seat or sitting on the floor near the center console. I just need to know the best way...
  3. M
    Tapping into the Cargo light
    I ran new LED's under the bedrail, so that my bed is lit when the tonneau cover is on. The wire runs up under the cab, and into the truck through the wire harness by the battery. I'm trying to find out where the cargo light connects in. The cargo light itself is a white wire with a fat red...
  4. Amazonica
    Adding 12V Power Receptacle to Bed - Wire Routing Advice Please
    Does anyone know of a thread where someone has added a 12V (or any type) of receptacle to their truck bed? I have a 2019 Rebel (regular bed, no RamBox) and an 37Quart ARB Fridge/Freezer I need to power. I already have the ARB receptacle add-on and need wire routing advice please. I'll be...
