06 hemi to 2010 charger block question Please Help...
Edward21
TX
so my 06 hemi Non MDS through a rod made a hole in the block i went a picked up a bear block and when i got home i realized it was from a newer car the front of the engine looks like a 2010 and up where the cam goes just wondering if all my 2006 parts will fit this 2010 block like my cam and cam gear, timing cover oil pump....also the 2010 has a VVT solenoid does that just stay in and unplugged
HemiLonestar
Navy Badge Coast Guard
MD
No you cannot use that engine without a serious amount of work. Go get the correct one.
HemiLonestar
MD
It's pretty much a different engine. Look for any 03-08 2500 engine. 03 1500 engines will also be an easy drop in (no EGR to worry about). The 04-08 1500 engines will have EGR you'll have to remove and plug.
Arturo Rojas
