1.25 RCX body lift and Bilsteins on today
suzukiquadrider
cummins 5.9, 6.6 duramax
Nice pickup, it almost looks like a 2500. that is a good deal on the lift.
durango4819
DE
4.7 V8
same set up as me, looks great! i like those tires you have now a lot
Black express
Hemi 5.7 VVT
What size and kind of tires are on it now. Looks good with those on it.
durango4819
DE
4.7 V8
dont forget to get those tips adjusted lol
srqFF
Sarasota FL
It looks pretty good man. Very subtle, but definitely noticeable that its not stock.
JasonK9
I was wondering that same thing. How can you adjust those tips and get them back up in the bumper? Imagining a smaller rubber bracket mount...
Musclemckeester
Houston, TX
n/a
n/a
The tips can be loosen and angled up as a quick fix or you can take it to an exhaust shop and have them either move the entire exhaust up or have an S pipe welded on before the tips.
JasonK9
I thought the tips are welded on as one whole piece? At least when I was putting on my Y delete, that's what I seen. With all the rubber mounts that support the exhaust, I'm guessing that would be only adjustable options unless you welded some brackets. I'd rather have that exhaust flexing than have the welds break off.
Musclemckeester
Houston, TX
n/a
n/a
Some tips I think are welded, some aren't. Mine aren't so I just loosened them and adjusted the tips up. The exhaust shop I went to wouldn't move the entire exhaust because they wanted to keep it all factory. They wanted to put in a S pipe and weld my tips to that. I have my tips painted black and they have to be repainted from time to time due to rock chips so I didn't want them to be welded on.
JasonK9
Mine are welded on. If I find the right shop, may they can cut the tips off, use a small piece of stainless to raise the tip, and then attach using clamps. Then they can be adjusted or removed later on if needed.
JasonK9
Thanks everybody. I'm pretty pleased with it.
Chrome Raceline Renegade 5s wrapped in 35x12.5R18 Kumho Road Venture MTs.
What size tire did you originally have on your stock rims and were there any problems? I'm liking the look but would want to get just a little taller tire.
rambob
LA/MS
318 5.2l
sounds like a good deal. looks great too.
BL is super easy to install, just takes a good bit of time due to all the body mount locations and other lift items.
New Rhino
