15% Off All N-FAB Step Products – Make Your Truck Stand Out
carid
Cranbury, NJ
Hemi 6.1
If you're aiming to upgrade your truck with both style and utility, we've got some great options for you. The N-FAB EpYx Black Nerf Steps are a fantastic addition, offering a clean, angular design that provides easy access to your truck. Crafted from strong steel with a black powder-coated finish, these steps are built to handle tough conditions while giving your vehicle a modern, rugged look.
For serious off-roaders, the N-FAB Black Rock Rails offer top-notch protection. These rails guard your truck’s sides and undercarriage from rocks and debris, helping to prevent damage when you're tackling rough trails. With their durable construction and sleek, low-profile design, they add a tough, aggressive touch to your truck without sacrificing ground clearance.
Looking for something practical yet stylish? The N-FAB 5.5" Roan Black Running Boards could be the perfect fit. These boards provide a wide, sturdy stepping surface, making it easier to get in and out of your truck. With their strong build and sleek black finish, they not only enhance accessibility but also give your truck a sharp, functional upgrade.
N-Fab® - 2" RS System Black Round Nerf Steps
Note: Choose your specific model in "Product Options"
Features:
  • Expanded sure grip step plate
  • 2" main tube fits tight to the body
  • Drop down step position at each door
  • Textured Black over OEM style E-Coat primer
N-Fab® - 5.5" ROAN Black Running Boards
Features:
  • Fully-welded heavy-duty steel tubing frame and top plate offers superior strength and durability
  • Load-tested to 475 lbs. capacity
  • Xtra large 5.5” x 21” louvered step plate positioned at each door allows easy and secure vehicle access in any weather condition
  • Adjustable mounting system designed for versatile fitment on stock or lifted vehicles
  • Bolt-on step plate is easily removed to allow for custom paint or personalization
  • Ravegr Running Boards come standard in a cab-length configuration and feature a textured black powder coat finish
N-Fab® - Black Rock Rails
Features:
  • Direct bolt-on applications, utilizing pre-existing factory mounts
  • Mounting brackets are welded to RKR rails for additional strength and durability
  • Non-modular, dual-bar welded assembly with 1.75” main tube diameter
  • Standard color textured black powder coating, using N-FAB’s 3-stage powder coating process
  • 5-year finish warranty / lifetime workmanship warranty
  • Optional detachable step sold separately (detachable step JPTS32 sold in pairs)
  • Sold as a pair with passenger and driver side
N-Fab® - EpYx Black Nerf Steps
Features:
  • Modern angular design that fits tight to the body for a clean look
  • Installation made easy with new modular brackets allowing for simple adjustment for perfect fit
  • Sold in pairs and as a kit with step rails and brackets packaged together in one box
  • Drop down step at each door engineered with an expanded step plate for ease of access to stock or lifted vehicles
  • Full steel construction for strength and durability
  • Textured black powder coat finish
You can browse the full catalog of N-Fab products on our website:
carid
carid
Cranbury, NJ
Hemi 6.1
Don't miss the opportunity to upgrade your truck with our selection of N-FAB steps! From now until 9/30/2024, you can save 15% on all N-FAB step products, including nerf steps, running boards, and rock rails. Whether you’re looking for easier access or extra protection, this limited-time sale makes it easy to enhance both the look and functionality of your vehicle. The prices are already reduced, so don’t wait—grab this deal while it lasts!
If you want to learn more about the N-Fab brand, please click the link below:
See other active promotions and coupon codes here:
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
I still like my slightly modified Nfabs better
originally it was on the 2009 Ram, they are now on the 2016
the Toe of my shoe fits better under the bar & my rears steps are lengthened
solid mounts
better than the original 3 step Nfabs
TMFMK
