Ignition Switched Power Location Under Hood - For Relay
EViS
United Kingdom
I require a switched ignition hot wire for a number of accessories (via a relay signal) on a 2015 RAM 1500. It seems that most people use the centre console power outlet as their switched ignition source. However, I need a switched wire under the hood in the engine bay.
Could I have some recommendations for where you guys get an ignition signal wire under the hood?
EViS
EViS
United Kingdom
Check your owner's manual, in the fuse section, for the fuse number that controls the interior power plug. The fuse has two positions: always hot and ignition-switched. Use a fuse tap to get your relay control signal.
I did consider this. However, I have already moved the interior power outlet fuse to always hot as this is more useful for me. Hence, I cannot now use it with an ignition-switched fuse tap (or can I?).
Fuse F66 should be switched with ignition
Grams
2024 & 2015
6.7 Cummins & 5.7 Hemi
Fuel pump fuse is only “hot” when the switch is “on”. A piggy-back fuse splice there should do the trick.
04fxdwgi
Coastal NE North Carolina
2016 1500 Sport
Never been a fan of piggy backing off some fuse that feeds a critical component. Seems that doing that to something, say like the under hood light or some other thing of low priority, would be a more logical choice.
Grams
2024 & 2015
A true “piggy-back” splice….does not hazard the original circuit… as it merely parallels it…. similar to every other circuit that comes off the battery-buss.
(but I understand the reluctance if you have another dedicated source)
04fxdwgi
2016 1500 Sport
Perhaps you should read what I said again. Said nothing about piggy backing being no good. I suggested piggy backing off a non critical circuit.
I would consider the fuse for powering the fuel pump a critical circuit.
But hey, you do you.
Grams
2024 & 2015
I prefer not to read blather more than once. ;)
BossHogg
Navy Badge Law Enforcement
Oakland Township, Michigan
6.7L Cummins
You fuse tap off the battery feed side of the fuse, not the load side.
04fxdwgi
2016 1500 Sport
Correct, but sometimes the fuse holder that you piggy back can become stressed by the adapter. I prefer to do that to a less critical fuse.
Been an industrical / automotive / marine electrical guy for over 55 years and and seen these kinds of failures all too often.
TMFMK
