side steps
  1. carid
    APG’s New Nerf Bars Combine Style and Functionality
    Hey truck owners, We’ve got something new from APG, a brand that’s all about rugged, reliable truck accessories designed for both style and function. Their latest release, the DS Drop Down Style Trapezoid Nerf Bars, is now available at CARiD.com. These nerf bars are built tough and designed to...
  2. carid
    Limited-time Offer: 50% off Black Horse Side Steps
    If you want an easier way to step into your truck, we have a solid choice. The Black Horse 4" Summit Running Boards give you a sturdy, wide step that feels secure under your feet. Their durable construction means they can handle tough use day after day. These running boards do not just help you...
  3. carid
    Big Savings on Magnum RT—20% Off All Products Now
    Looking to enhance your truck or SUV with both style and practicality? We've got you covered. Our Raptor Series 4" Magnum RT Side Steps are the perfect addition to give your vehicle a bold, aggressive look. With their distinctive angular design, these side steps not only make a statement but...
  4. carid
    Save Big on Steelcraft Power Glide Retractable Running Boards
    If you want to enhance your truck's functionality and style, we've got just what you need. Our Steelcraft running boards and side bars are designed to make getting in and out of your vehicle easier, especially if you have a taller truck or SUV. Made from high-quality materials like stainless...
  5. carid
    Save 15% on APG Nerf Bars and Side Steps This September!
    If you’re looking for an easy way to boost your truck’s appearance and functionality, CARiD has the perfect solution. Our selection of APG Nerf Bars and Running Boards are designed to provide both style and strength. Whether you’re tackling rugged terrains or simply want a more comfortable step...
  6. Hooke Road
    Hooke Road Nerf Side Step Bars
    Hooke Road Nerf Side Step Bars Feature: ● Weight: approximately 62 lbs; ● Function: to protect the side of the car and to facilitate getting in and out of the car ● Three brackets on one side ● Easy to install, in the original car's holes, use the equipped screws to install;
  7. carid
    15% Off All N-FAB Step Products – Make Your Truck Stand Out
    If you're aiming to upgrade your truck with both style and utility, we've got some great options for you. The N-FAB EpYx Black Nerf Steps are a fantastic addition, offering a clean, angular design that provides easy access to your truck. Crafted from strong steel with a black powder-coated...
  8. B
    Attaching side steps-hardware
    Steps came w/o hardware for attaching. Plus bolts are painted on the truck.
  9. Frisk
    Paint for Ram Side Steps
    I have a set of black Ram Side steps on my 2016 Ram 1500. The steps are holding up well except for the area were by foot goes the paint has worn off. I have the driver's seat set are far back as it will go which means that when I step out of the truck my foot contacts the side step not on the...
  10. A
    2022 Ram 2500 OEM Running Boards
    I made the mistake of not ordering running boards and now that my 2022 RAM is finally here my family has trouble getting and and out of it. Tried doing a bunch of research, but things are not all that clear. My #1 choice are the "Painted Flat Wheel-to-Wheel Side-Steps" (to match the Night...
  11. M
    Can anyone identify these nerf bars?
    Looking for some help identifying these nerf bars. Specifically looking for ones that extend past the cab in the rear. Thanks in advance.
  12. Dan90
    2017 SPORT WHEELS, EXHAUST TIPS, NERF BARS, LEVELING KIT
    2017 Ram 1500 sport wheels with Nitto tires. Tires are 285/65R20 (35X11.5) Nitto Exo Grapplers. 34,000 miles on them. About 11.4 mm of tread or around 14/32. Wheels are in very good shape. Willing to separate wheels and tires. Pick-up only, located in Midland Michigan. I would be willing to...
  13. G
    Quad Cab Steps/Running Boards
    I just purchased a 2020 Big Horn Quad Cab and I underestimated how high the truck is. I like the look of the factory installed side steps but I am having trouble determining the OEM part number for the stainless steel wheel-to-wheel running boards for the quad cab model (the dealership is far...
  14. T
    So... how much hardware is missing from my factory side steps?
    Preamble- from my inspection it seems the 1500 and HD trucks for 2019 use different mountings for side steps, so this thread applies to HD specifically. (Classics might be the same, I haven't checked) Issue 1: Today I'm under the truck closing up the taped over holes in the rockers, and I noted...
  15. Tonneaucovered
    We offer more then just Tonneau Covers
    In addition to Tonneau Covers, we also sell Side Steps, Bed Steps, Bed Rugs, Floor mats and more. Give Peter or Shaun a call today for a quote.
  16. OEDRO
    4 inch Running Boards, Best Deals Here, Up to 30% Off
    OEDRO’s running boards use the latest technology to protect your Dodge Ram 1500 while offering the support you need. Made with all-in-one heavy duty steel tubes that offer the best in durability, corrosion protection, and strength. OEDRO 4 inch Running Boards, for 2009-2018 Dodge Ram 1500 Quad...
  17. H
    OEM part number for Ram 1500 Lone Star W2W running boards?
    Hello all. I'm on the hunt for a set of OEM Ram 1500 Lone Star Crew Cab wheel to wheel running boards to fit a 2016 Ram 1500 Laramie Crew Cab (Pictured below). Near as I can tell these were only offered on the Lone Star Silver edition. Is that correct? Either way, can anyone provide the OEM part...
  18. S
    Unable to remove oem step bars
    Im having trouble removing my stock step bars on my 2008 ram. The two bolts that mount the steps to the body keep spinning. There’s some kind of tab on the other side of the bolt (that i can’t access) which is preventing the bolts from coming all the way out. Does anyone know any tricks or what...
Carbary
