15 ram 6.7 Cummins turbo actuator noise.
Neilm
Washington state
I have a 2015 ram 3500 with a 6.7 Cummins that had a non VGT turbo when I bought it. Recently I put a new ATS aurora with a vgt and converted it all back. Everything works as it should but I do notice a noise from the actuator when shutting down like it’s switching on and off. Anyone seen or heard this? Is this an issue? Solutions? Thanks in advance! (I have a video but don’t know how to attach it)
Cummins diesel
Kentucky
2015 Longhorn
Cummins
I’m not sure exactly what your hearing but my truck also sounds like the turbo actuator clicks a few times right after the truck shuts off.
nlambert182
Huntsville, AL
They can sound loud when nothing else is running. If it's actuating properly I wouldn't worry about it.
mtnrider
Georgia
Normal, the actuator will do a "sweep" at shutdown, that might be what you are hearing. There are lot of other things that reset or align during shutdown/startup so you might here other noises.
A good rule of thumb, unless it throws a check engine light it's fine, these trucks are very good at letting you know when something is wrong.
