2005 dodge ram lift questions
alex2929
Wisconsin
I have a 2005 dodge ram 2500 quad cab 4wd with the hemi, im looking to put a 2in-2 1/2in leving kit on it and was wondering how big of tires i can fit under the truck then, have advice would be great!
NWRQC
Depending on the wheel width and offset you can fit up to a 37. For most cases fitting a 35/12.5 won't be a problem.
I am running a 20x9 +10 offset wheel with 35/12.5/20 Nitto Terra Grappler G2's and the tires will rub slightly on the back side of the fender well. I think once I some longer control arms (to recenter the wheel) I won't have any rubbing problems. If I had a little less offset (few MM) I wouldn't rub at all. Oh and I have a 2" level.
A
alex2929
Wisconsin
thanks that answers alot of my questions! is they any additional wear i will have to worry about with the leveling kit? Also is they anything else i should but besides the leveling spacers?
A
alex2929
Wisconsin
NWRQC do you have any pic of your truck looking front to back? would like to see how much your tires stick out.
NWRQC
I would get some longer shocks
I'll see what I can find, if I don't have any I'll take some later.
NWRQC
Here are a few.
A
alex2929
Wisconsin
Correct me if I'm wrong but positive wheel off set will will make my tires stick out past my fenders and negative with push them back in more?
jwheeler
Washington
You are wrong. It is the other way around.
sublime2300
