spoolinlust
Hello, this is my first post to this forum. I have done some searching and have found a lot of useful information but still have a few blanks to fill in while gathering everything I need for my 8hp75 4wd drive swap.
I would love to do a detailed step by step write up that's not contaminated with random tangents etc. same on YouTube. Shorts are great but always derail one way or another. Usually someone ranting about there dog and whatever else OR incomplete.
If your like me, my research opportunities are scarce and scant.
This will be going into a 2004 5.7 ram 1500 4wd quad cab Laramie
What I have so far:
4wd 8hp75 out of a 2019 ram 2500 6.4L
TCase
Torque converter
All the above came from the same vehicle
Sound German Automotive controller
Sound German Flywheel
Charger gear selector
-6an cooler adapter at trans
Aftermarket trans cooler
Items I haven't sourced
4wd dial selector
Needs the tcase motor
Front drive shaft
Rear driveshaft
Mounting components
The cash!!
The items I am struggling with are:
-Front drive shaft need advise on who makes one or if it's custom
-Rear driveshaft yes there are custom shafts out there but are about $1.5k well worth it for a drag setup, that's not me. I can have my local drive line guy take my existing and Frankenshaft something but just wanted to see what others have done.
-Mounting situation the write ups that I have seen are either 2wd and well detailed but not the same as 4wd so not much help OR 4wd set ups that do not really talk about the mount.
It looks like the 545 mount may work; TBD.
I appreciate any and all help.
What I have so far:
TCase
Torque converter
4wd dial selector
Front drive shaft
Rear driveshaft
Mounting components
The cash!!
