2007 Wheel Wobble
clintr
2007 Ram 1500 wheel wobble when going over 50 however it's intermittent. Changed a worn strut and had the tires balanced. Still there.
Doing some looking around and this is the only thing I can find. I'm not sure how to fix this. I would assume a clip of some sort is missing causing this wobble on the intermediate shaft. Or is it the half shaft that just needs replaced? Thanks for the help
Jerseystyle
That could be it but did you already check your wheel bearings?
Sent from my SAMSUNG-SM-G890A using Tapatalk
C
clintr
No I haven't. I haven't really had any other symptoms other than the intermittent vibration. I will check however. I now have a new cv axle. Haven't had a chance to drive enough to say one way or the other if it's fixed.
gville35
