2011 CC Sport Build Thread
rusties93LE
360 magnum
I know this is off topic, but I want to thank you all for your service to our country, so we can enjoy our trucks!:gunner:
Cruizer
Ohio
2010 Sport 4x4 QC
^^^This! And, I wanna thank you for building a badass truck I like to look at.
tones2SS
MA
3.3 tt
That truck is beastly! Good job man.
rwalk
Westford, MA
4.7L V8
Fab fours bumper? How did you work around the body lift?
EM2(SW)
EM2(SW)
Norfolk, VA
It is an Iron Bull bumper. i just reused the same bumper brackets that were used with my stock bumper but the mounting slots are vertical and im sure if i went in the very bottom of the holes it would have been flush.
scottyram
Ontario Canada
I think the overall look of the truck improved with the new rubber. Nice work!
CUtigerfan
SC
Can the OP or someone else explain this particular suspension setup? Not new to the forums and trust me I know about the search function... but I am new to these trucks and only want to lift mine once the right way. It seems like he's got multiple lifts stacked together to achieve a really aesthetically pleasing truck but how does it handle? And how is suspension travel and CV angles effected? I'm also new to a 4wd.
EM2(SW)
EM2(SW)
Norfolk, VA
The 6" RCX is suspension and I have no complaints on how it handles w/ the Bilstein shocks. I'm sure the ride would be a bit smoother if they were not adjusted all the way 2.8 but the ride is fine to me. The 1.25 body lift is simply raising the body from the frame to achieve a little extra lift and does not interfere with the 6" suspension lift what so ever. The RCX lift has a drop down bracket to maintain your CV angles. And the 4.56 gears really bring all of your power back after adding the large tires
brasso
2012 ram 1500 4x4
Vararam, 87mm TB, and BT Catch Can Installed:
Needs some cleaning under the hood just too cold to mess with it right now.
What gains did you see out of these mods? Worth the money?
EM2(SW)
EM2(SW)
Norfolk, VA
I did all theses with a tune and went from 9.5 mpg to 14 mpg
jhicks1983
