2012 1500 with 4.7 dies occasionally on road
wafogg
Indiana
I have had this truck for about a year and a half and about every 1-2 months it will die on me when I am driving. It only does it when I come to a complete stop. This is what happens when it dies- I come to a stop at a light or stop sign and when I fully stop it dies on me. I am always able to turn the key off then restart the truck immediately. I then can continue on with with driving and not have another issue for sometimes months. Has anyone ever experienced this before?
Jeepwalker
WI
2012 Reg Cab, 4x4
Does it stumble a little first before it dies, or does it die like someone turned it off? A few simple things I would check (in order of most to least likely):
1) Carboned up throttle-body bore - Easily cleaned with throttle body cleaner and a plastic bristled brush. It doesn't take much fuel/carbon to throw things off. I have a GM vehicle that was dying and the tb was fuel 'gummed-up' pretty bad ..needed a good cleaning. This is routine maintenance.
2) Worn Spark plugs . Inspect and replace if necessary.
3) Worn out (or weak) MAF sensor. MAF sensors can become dust covered over time (or oil covered if you have a K&N filter) ...and they don't live forever anyway. They can put out a signal barely within the 'good' range so it won't throw a code, but yet can lead the computer to cause opreational issues, usually seen at idle. I've had this happen. Often a quick cleaning with MAF cleaner can help and restore it higher into the 'good' range. MAF cleaning is periodic maintenance. If you have a scanner you can see the voltage output and see it's output.
4) PCV valve plugged , not sealing, or cracked PCV hose (sucking raw air).
5) Vacuum hose leaks ..or Vacuum leak somewhere else.
6) Fuel pressure issues (weak/failing pump, etc)
7) EGR issues. I don't remember on the 4.7 pickups, but on my Jeep GC with a 4.7 the EGR pipes are made of plastic with molded rubber elbows and T's. Due to age and heat, they become brittle and can crack causing the EGR to suck in regular air. So these are worth checking.
I'm just throwing out things I've encountered, and on vehicles I've worked on. Could be a combo of 1-4 ..which are maintenance items that are easy to creep up on an owner. All of these are fairly simple to check and not expensive to resolve.
indept
South Jersey
The crankshaft or camshaft position sensors could be going out.
W
wafogg
Indiana
Thanks for the tips guys. I'll start checking that stuff out. Regarding your question, Jeepwalker, it does seem like when ever it is about to die I can see it coming. Whenever I am braking it will sort off lag a bit like it wants to stop before i have fully depressed the brake pedal. Then when I do depress the pedal fully to stop it dies.
