2013 (-14?) Heated seat switch assy (gas)
Status
Not open for further replies.
Mpgrimm2
Supporting Vendor Navy Badge
SC
2022 Ram 1500 (5th Gen)
5.7L
Cleaning out my storage area and have the following switch assy it's clean but has some wear on back edge of the buttons that will likely never be seen once installed ...
PN: 68137063AA
$40 OBO shipped to lwr 48 states.
Online search shows it should be for 13-14 trucks (out of a 13Ram1500 Sport). Please verify for your use.
Send me a message if interested
M² Mods.
Mpgrimm2
Mpgrimm2
SC
5.7L
... The Laramie seats require the 8.4 radio in order for them to function properly and they are a little more involved than the standard heated seats. Not having the switch panel could definitely be the issue you are having with the heat and vent not working correctly. I haven't seen anyone install them without the switch panel so I can't give you a definitive answer but it's definitely the next step I would take.
Remember the 13 Ram takes a different switch panel than the 14 to 17 so if you purchase a used one make sure it's from a 14 or newer...
Ramit2016
Chesapeake, VA
It will work if I just have a heated wheel but not heated seats?
You would need heated front seats in order to for the heated wheel to work. There is a seat module that controls the heat functions and that would be mounted under the drivers seat with factory heated seats. It may be possible to get the module and run the necessary wiring to get it to work but I haven't heard of anyone doing it and it certainly wouldn't be cost effective just for a heated wheel.
Mpgrimm2
Mpgrimm2
SC
5.7L
Mpgrimm2
Mpgrimm2
SC
5.7L
Mpgrimm2
Mpgrimm2
SC
5.7L
Mpgrimm2
Mpgrimm2
SC
5.7L
Mpgrimm2
Mpgrimm2
SC
5.7L
Mpgrimm2
Mpgrimm2
SC
5.7L
Mpgrimm2
Mpgrimm2
SC
5.7L
I forgot about this.
Price lowered to $40
M² Mods.
circuitguy
Elk Grove, CA
2017 Ram Tradesman Regular Cab
5.7L HEMI
Think it will work ok all the way up to the 19 Classic.
Mpgrimm2
Mpgrimm2
SC
5.7L
Not sure. I think something changed in 2014. @Ricks Ram and @DeereGuy may know more. I traded in my 13 ram before I found a decent set of seats.
M² Mods.
Mpgrimm2
Mpgrimm2
SC
5.7L
Mpgrimm2
Mpgrimm2
SC
5.7L
Mpgrimm2
Mpgrimm2
SC
5.7L
Mpgrimm2
Mpgrimm2
SC
5.7L
Most likely not since 09-12 trucks are electrically different than the 13-18
M² Mods.
Mpgrimm2
Mpgrimm2
SC
5.7L
Status
Arturo Rojas
