2015 RAM 3500 Limited - Unable to re-enable TPMS
7TCUDA
Airdrie, Alberta, Canada
2011 and 2015
On my 2015 RAM 3500, I disabled the TPMS as I had separate winter rims without the tire sensors. Apparently I did a very good job. I had documented what I did, and reversed those settings. As far as I can tell I have followed and double checked every setting I have found online as well. I do have the image on the EVIC, but it is showing blanks. I get the TPMS Fault on startup. I have a AUTEL reader/programmer but it will not connect to upload readings to the truck either. I have gone into the RF Hub and manually entered the sensor ID's as per my scan tool. I can't really go back to an old backup, as I have made other changes to the truck configuration. Is there a setting that is not obviously for TPMS on the menus that I could be missing? Yes I have reset the RF Hub.
Anyway, can someone walk me through their working TPMS settings? I am a really bad looser and this has me beat.
SSGart
