tinner93
Hello, new to this forum and looking for some help or insight into a particular problem.
The front of my rebel is completely down on the stops ( so much that the caster/camber is way out)
I replaced fuses and relays
If I jumper out the relay the compressor does come on
Holding the buttons for 40 seconds does nothing, not even the chime but will throw new codes up saying buttons are stuck.
Tried every option form the screen and get no reaction
When hooked to the alfa obd ( also tried the icon t7) almost every test function doesn't work ( cannot complete test, ecu encountered a problem )
The few tests that will work don't actually do anything even though it's says complete. Fill , deflate, test say complete but the compressor never cycles
Check air ride sensors test says test complete but nothing happens.
I bled the nitrogen out manually through the right service port on the manifold and refilled with nitrogen ( rear bags stayed inflated when the charge was removed from the tank)
With almost every function from in the truck and from the scanners not doing anything im starting to believe the problem is the ascm.
Just looking for some advice before purchasing a ascm.
I am new to the air suspension but not to rams.
Any help would be greatly appreciated!
