2017 32 gallon tank
Memo
Maryland
Does anyone know if the 32 gallon tank have a debris filter on the neck filler? I was fulling my truck when i noticed late a piece of black plastic on the edge of the lip and when i placed the fuel nozzle in I knocked it into the neck. It looked like it was about an inch long by 3/16 thick.
Should I drop the tank and try and find it in a black tank?
Any suggestions
SeppW
Northern VA
Hemi 6.4L
Could run a piece of hose or tubing down the filler hose and see if hits a screen. Dropping the tank could be a major undertaking, IMO. Probably not an issue as the in-tank pump has a screen. Is the cap breaking up?
M
Memo
Maryland
Thanks for the input and no the cap is still intact. I will check to see if there is a screen on the neck.
2003F350
6.7 CTD
I agree with this. The mesh screen on the in-tank pump will filter out most debris that could damage the pump itself, so if it was a sizeable chunk of plastic/rubber then you're probably fine.
Lemniscate_Mike
