I have a 2019 Ram Classic (Gen4) Bighorn Quad Cab with a 5.7L Hemi and a trailer-tow package. It's worked fine with two bumper-pull travel trailers, and this spring my wife and I bought a 'half-ton towable' Grand Design Reflection 22RK 5th wheel. The rig pulls it fine, but in going onto a Cat Scale, it's right about at the maximum Combined Gross Vehicle Weight rating.
I have a chance to pick up a 2018 Ram 2500 with the 6.4L Hemi, in a Crew Cab. It's a 'Tradesman' model, but has all the trailer-tow features mine does, and most of the 'convenience' features as well. The owner and I each had a 2015 Eco diesel with the myriad problems associated with those, and dumped them and bought our Hemi-powered trucks about the same time in the summer of 2019. (Though he bought the 2018 'on the lot' while I ordered mine as a 2019 model.) He passed away 5 years ago, and his widow (who goes to our church) told me "I haven't driven that beast 3000 miles since he passed away." It's only got 42,000 miles on it, while mine just turned over 97,000 miles.
Everyone is telling me I really should be towing that RV (~ 6500 lbs. dry weight) with a 3/4 ton truck - which I don't disagree with at all. We want to pull the rig to Alaska next year, and I'm not sure my 1500 is up to that kind of towing torture. (Plus the wife just retired, so we're going to travel a lot more.) The gal gave me her VIN and I received a build sheet from Ram on both my truck and the 2500, so can compare every feature. Overall, it's a better truck for towing this larger RV. I know I won't get nearly the overall fuel economy (mine gets 9 mpg towing, but around 20 mpg just driving around empty) - though people told me the 6.4 would not be any worse pulling the RV. The 2018 does have only the 6-speed transmission and 3.73 gears, while mine has an 8-speed and 3.55 gears; so that will likely affect the towing ability and cut down on the fuel economy. (I always tow in 'tow/haul' mode.)
Any 'gotchas' with the 2018 2500 I should be aware of? As mentioned, it is a crew cab, but (according to the dealership I got my fiberglass cap from) since mine is a 'Classic,' the cap will fit fine on the 2500; both have 6'4" boxes with identical dimensions.
If I'm reading the build sheet correctly, it's got the 'puck' trailer tow feature in the box, so I'd have to swap the 5th wheel hitch type I have in mine (heavy brackets bolted to the frame that tie the hitch rails in the box to the frame) for one that matches the pre-installed 5th wheel 'puck' system. (Or maybe I can bolt mine into the 2018 and not switch to a 'puck' hitch.) Other than that, it seems like a good deal; the gal is considering a 'trade' for my 1500 (plus some cash.) She and her late husband are a 'known' quantity and both are meticulous about maintenance and vehicle care.
All comments/concerns are welcome! Thanks! - Mark in Michigan
