2021 ram 2500 led fog lights.
Alvaro0528
Lake Elsinore
I have a 2021 ram 2500 big horn, I had halogen headlights and fog lights. I switched to the led headlights and fog lights. I got the headlights to work with alphaobd but the fog lights are not turning on. I enabled led fog lights but still nothing. On my dash the green light is on with no error code. Are the fog lights no good or do I have to enable something else with alphaobd? Thanks in adavanced.
Jimmy07
On the two-way connectors that plug into the fog lights, you have to reverse the two wires in those connectors.
Cumminsmaster5000
MN
Cummins 6.7
Alvaro did this work for you? Or did you have to change some thing else in alphaOBD?
A
Alvaro0528
Lake Elsinore
Sorry for the late reply. It worked perfectly. Just make sure you enable the led fog with alpha. Nothing else needed.
ameer73
