2022 Ram 2500 6.7 DPF Filter 100% full.
Herefishy
FL
The truck was reading the PCM after I installed the bypass plug. I followed the instructions and tried to initiate the regen. The software said there’s one bad parameter and that’s because the codes aren’t erased.The truck is still drivable it’s not in limp mode yet. It has 55,000 miles. I’m to blame for this because I wasn’t monitoring the DPF filter. I have a local company that’ll clean it for $350. Any advice on removing the code now that I have the proper Alfaobd software.
jejb
NW Arkansas
You may want to check in the Alfaobd forum here. I don't use that, so no help otherwise:
Gr8bawana
6.7 CTD
I find it amazing that a '22 with only 55k miles could have a full DPF. o_O
Perhaps a faulty sensor?
