2024 2500 ram fuel filters.
topdog12468
ontario, canada
6.7 cummins
hi all,
Just wondering when you should drain the water from the fuel/water separator?
Also when should you replace the two fuel filters?
Thanks,
P.
Units
Ms
2023 Bighorn
6.7l Cummins
Outside of the regular service intervals, only time you should need to drain water from the fuel filters is if you get a warning light on the dash for water in fuel. At that point pull over immediately and drain the fuel filter housings; it’s in your manual.
06 Dodge
Forest Grove, Oregon/soon Osage Iowa
6.7L CTD
hi all,
Thanks,
P.
Being you live in the cold country I would drain both filters before the over night temps stay at or below the freeze temps of 32 degrees, yes you can go a full year an not drain it or have problems, but I say why chance it? IMHO its best to drain the filters before cold temps... The below is from my owners manual:
Diesel fuel is seldom completely free of water. To
prevent fuel system trouble, drain the
accumulated water from the fuel/water separator
using the fuel/water separator drain provided on
both fuel filters.
