Rammered
I went the route of putting a 2500 bumper on a 1500 4th Gen. I didn't know the Ram lineup before I bought this Destroyed truck.
So I call mine the Polock.. Its got hint's Power wagon and the Warlock
I'm not done with this yet.
Whats involved you ask... a serious pain in the butt...
So I used the
STANDARD HOOD
AFTERMARKET REBEL GRILL -WITH SQUARE CORNERS- I think its shorter. bottom edge of grill lines up with the plastic parts under the headlights.
SORTA-FIT 2500 bumper.
Plastic shrouds under headlights.
Fender liners for 2500. I have not bought these yet.
Im waiting on bolts to put the show hooks on.
Still got to paint the matt black.
Serious custom brackets. to mount bumper. I have read someone else saying this is easy. Maybe for a full time fabricator. I bet i put this bumper on off 6 times before i knocked out a solid plan.
Also if you want to use the show hooks you will need to mount them to plates to shift off center.
This whole thing took some serious engineering to get to fit up to the standard frame plates correctly.
(not Modifying them)
The 2500 frame is wider without the frame pates on end.
Would there be any interest in fab kit???
The bumper brackets are very large made of .100 steel same as bumper thickness. These brackets replace the 2500 brackets completely.
The show hooks plates are 3/8" thick. I call them show hooks because there not intended for use.
So I used the
STANDARD HOOD
