2500 Diesel radiator replacement
mountaingoat11
Leland Meadow Ca
Diesel
Can anyone tell me if the radiator comes straight out or do I have to remove the grill and everything around it. My fan hit the fan shroud and destroyed it putting a hole in my radiator.
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
On the Ram 1500s, it only takes
a few plastic push pins that hold the radiator cover on
Then 6 bolts remove the grille, they are different threads, so remember where they go, some are for plastic, some for metal.
Then you should be able to see everything else
cdub5
