$38 LED Light Bar Roof Brackets
wedge775
Phenix City, AL
Light Bar Brackets 2010 2015 Dodge Trucks for 50" 52" Bars Sale Roof Mount | eBay
Went ahead and pulled the trigger on a set of these brackets. They look good, and seem very sturdy. The paint, could have been better, gonna sand mine down and color match mine. Mounting hardware was just eight self tapping screws, believe I will be replacing those with some rivet nuts and flat head bolts. These brackets are supposed to fit 50"- 52" bars depending on the brackets mounting location. Also suppose to fit curved bars as well. Will update this this thread as my project comes along. All I am lacking is the light bar, haven't decided which to get yet.
wedge775
wedge775
Phenix City, AL
Nice, you have joined the "LED Addiction"...
HAHA, everything is LED on my truck. Only lights that aren't, headlights, fogs, and my 6" KC's. Wanna convert my KC's to LED so bad, but what KC wants for the conversion....ouch!!
wedge775
wedge775
Phenix City, AL
Got the brackets and bar all installed and hooked up
wedge775
wedge775
Phenix City, AL
two more pics
develand
What bull bar are you running and do you have a side profile shot?? Thinking of getting one and adding LED to that type of bar.
develand
That doesn't look bad at all. I have a '14 regular cab express and go back and forth on them.
homebrew
Cummins
Those look similar to the cjc brackets that I'm running looks like it positions the light a little farther away though. How sturdy are they?
wedge775
wedge775
Phenix City, AL
They seem pretty sturdy, 1/8" steel. I can hit the bar with my hand and get very little vibration outta it. The 52" bar is a very tight fit between them
VanCityRob
I bought the exact same brackets off of eBay. BEWARE if you off road!!! They are not the sturdiest brackets, I already had one screw snap out of the 8 from a logging road and the "powder coating" prep job was definitely not done properly as mine already are starting to show signs of giving up. Every time I hit a big bump they make some noise. You get what you pay for I guess
madrock
How did you run the wiring? Did you end up using the rivet nuts?
VanCityRob
I ran the wire down the door jam than through the fire wall. I'll post pics of it all tomorrow, trucks getting lifted at the moment
VanCityRob
I put a 52" curved bar on it and I would say they could be sturdier. Going through some mountain passes it can get pretty wash boardy and it wiggles enough to start digging into the lip of the door jam.im going to have to remove it and put foam tape on it so the corner doesn't dig in any farther. It's already starting to rust my truck. Just keep an eye on it if you 4x4.
wedge775
wedge775
Phenix City, AL
As said by another, wires ran down under the windshield trim. No I did not use the Rivet nuts, they wouldn't fit. Not enough room for them. I ordered some Jack nuts, gonna try those since they collapse differently than a rivet nut.
Glowz
