4gen Emergency/Warning lights
jcat
Have been doing some research and found that there isn't much in the way of what people are running for emergency warning lights on their 09-14 rams.
I'm a Volunteer firefighter and am looking to set my truck up with some warning lights pretty soon, so I'm interested to see what people have done. My goal is the most stealthy, undercover look possible when not activated, but bright as hell when activated.
Here's the preliminary plan:
-1x Recon 60" white lightning tailgate bar, brake/signal/rev when normal, then alternate red/white when activated by flasher.
-2 or 4 small 4 LED pods set up in the rear window
-2x LED flood/warning bars from Strobes N More behind the lower grille sections. Separate switches for flood, warning, and flash pattern. See below:
http://www.strobesnmore.com/Strobes-N-More-EFlood-4200-Warning-Light.html
That's all I can really think of to do for sure on this thing for now. I can't run anything like a dash/visor light or anything that's blatantly obvious due to certain restrictions, I like the idea of using Feniex cannon hide-a-ways as bulb replacements for front turn signals (amber for signal, red for warning) and reverse lights (white for reverse, alternating red/white for warning) but can't seem to get a straight answer on whether that's doable or not.
There's also these:
https://www.superbrightleds.com/moreinfo/specialty-high-power-led-spot-lights/18-redwhite-led-off-road-light-bar--24w/1855/4248/
Those seem pretty cool, but not sure whether they'd be as good a fit as the EFlood 4200 I posted above.
J
jcat
nobody's got anything in their 4th gen? Interested to see other peoples' setups...
