4in zone lift with stock 20s
dhows31
Mississippi
What size wheel spacers would I have to run to fit my stock 20s with the zone 4in lift. Any help is appreciated.
NoveskeFan
Historic Triangle area in VA
2017 Crew Cab Short Bed Copperhead Sport 4x4
I believe 1/4" is what people are using. I'd like to lift mine but I have the 3.21 gears.
brandonjansen
Abbotsford, BC, Canada
2012 Ram 3500 Laramie Limited
All depends on what size tires you want to run. If they're narrow, you won't need spacers at all. If they're wider than 295 then you'll trigger the need for spacers. What size are you looking to run?
dhows31
dhows31
Mississippi
I guess I should've included that info. But I'm running 35x12.50R20
brandonjansen
Yes you will need spacers to run 35x12.5's on the stock wheels. I recommend 10mm hub centric spacers from Motorsport Tech.
dhows31
dhows31
Mississippi
Is that enough? I've heard up to 1 1/2 in
brandonjansen
10mm is enough to clear the suspension. Anything larger than that guys are doing just for looks. 1.5" will make your stock wheels equivalent to a 20x9 -19 offset which will simply give you a wider stance.
makodiver
Ive looked at motorsport tech and havent found 10mm spacers only 1" to 4"
Sent from my SAMSUNG-SM-N900A using Tapatalk
6.7CumminsDrvr
The Dude abides………
Georgia
They'll make pretty much any size you want, give them a call. Also, IIRC, the 1.5" is what will completely cover you stock wheel studs so you won't have to trim or replace them. Sometimes there is a clearance issue if the studs are sticking out too far for some wheels.
Glowz
