mrpineapple
- Oct 6, 2014
- 3
- 3
- 2005
- Hemi 5.7
Hello all, I've been lurking all over these forums for about a week now and has come in handy several times. I am pulling my hair out over this pickup that I just bought with a blown engine.
2005 Ram 1500 with the 5.7 Hemi, it dropped 4 valve seats. I pulled the engine and sent it to a machine shop had them replace all pistons rings and bearings. They ended up boring the cylinders .030 over but the bearings were all standard and no need to grind them down. Heads had all new valve seats put in and all valves and guides checked (two valves were bent and replaced).
I got the engine back in the truck last week (I did all the labor except for the engine work) and went to crank it for the first time and it wouldn't start unless I pushed a fair amount on the gas pedal. It seems to run okay if I give it gas in the 2k-3k range it sounds okay but the idle is really rough. I drove it to get some fresh gas and treatment and it got slightly better with the idle but still isn't right. It makes no difference if it's warmed up or not.
Occasionally I get codes for both banks being rich and a cylinder 5 misfire.
So far I have checked/replaced:
Fuel pressure-steady at 58psi
exhaust back pressure- in the green (according to autozones rental tool)
Upstream O2 Sensors
EGR
New OEM Intake manifold+gaskets
Plugs (OEM copper ones)
Wires
Cleaned PCV
Double checked valve timing
No broken valve springs
All rocker arms move correctly
Compression at 100-120 psi for cyl 2,4,6,8. Will test 1,3,5,7 tomorrow. (I think it may be low because of the harbor freight compression tool not having a shrader valve on the spark plug fitting)
checked intake manifold gaskets for leaks
Today I pulled the plugs on one bank and noticed they were all wet, can't tell if oil or fuel. When I took the intake off I noticed a fair amount of oil residue, so I assume it might be that on the plugs.
Im thinking tomorrow I might replace the PCV and MAP sensor, but other than that I’m running out of ideas.
Also noticed today when I was pulled off the intake that cylinder 5 had some crap on the manifold. Picture attached, I cant tell if its carbon buildup or if it melted the plastic. Either way this happened with just idling and driving to the gas station <10miles. It was a brand new intake so all this just happened.
Any help appreciated! Thanks
Photo of Cylinder 5 intake manifold port
Video of engine running You can hear an exhaust leak, that I will investigate more tomorrow. Also probably notice the intake tube is off, the IAT sensor is still plugged in fyi.
Upstream O2 Sensors
EGR
Wires
Cleaned PCV
