5 in suspension lift & 3in body
dodgechick14
jersey
i currently have a 5" suspension lift on my 1500 and would like to add a 3" body lift. i think rough country said i could only go up to a 36" tire but i have 35" now does anyone know if its possible to put on 37s?
rwalk
Westford, MA
4.7L V8
With the 3" Body Lift added on you should have no problem fitting 37's, as long as your wheel does not have a highly positive offset
argray90
NW Burbs, IL
I'd have to agree with rwalk should be no issue fitting them.
D
dodgechick14
jersey
shes got an ifs not sure if that matters but my offset has to be 5.5
tommyboy
southern NJ
4.7L
Your Back spacing should be around 4.5" for a 4x4 1500. You will clear 37s no problem with a total of 8" of lift.
4X HEMI
Lancaster County, PA
I know a few 3rd gen owners with a 6" lift with 37's on with no issues. I know some running 35's at the stock height on the 1500's!
You have a 5" lift, you will have no problems with 37" tires after a body lift either. I run 37's and have plenty of room for bigger tires. I was thinking of putting 40's on mine.
