Leveled ram 1500 2012
Jtouma219
Nh
I have a 2012 ram 1500 crew cab 5.7. It has a rough country 3in level, and 33 Toyo open country’s. It has a vibration 50mph+ and I can’t seem to figure out why. Alignment is good, all tires road force balanced and force is <25lb. I did do the extended UCAs and extended CV axles. I have a big list of new parts I put on the truck too, but still getting a shaky vibration. Any ideas help, thanks.
Jake1031996
Minnesota
3.6 pentastar
Is it a spacer lift? Some spacer lifts can give real bad vibrations at certain speeds or you feel everything in the road. All your front end parts tight?
Daw14
South Florida
Have you checked u-joints , carrier bearing ?
Checked front wheel bearings for play or noise while rotating ?
J
Jtouma219
Nh
Yes, rear driveshaft ujoint, the one that goes to the diff was replaced. I removed the front driveshaft temporarily to isolate that too . Front wheel bearings were replaced recently and I did recheck for play but didn’t see anything.
Thanks for the reply.
J
Jtouma219
Nh
It’s on rough country N3 liftstruts. Everything in the front end definitely feels tight, and I did replace the UCAs with upgraded ones as well.
KAKA
