5th Gen style taillights for 4th Gen Ram
sealw98
detroit
I just picked these up pretty nice so far! I have a video too on YouTube
ric221
Do you get any type of errors like turn signal bulb out or hyper flash? I ask because I installed some of those and had those problems. Are your tails incandescent or led
Sry I see you have a 19. In case you have any issues I have a set of OEM 19 let's for sale
S
sealw98
detroit
No problem except the reverse lights were not working at first but solved that problem. I have a 19 classic with incandescent bulbs.
NL74
Looks good. Are those just oem 5th gen tail lights? Curious if you get any errors or issues. That would be a cool change.
Edit- Just saw you replied above and mentioned an issue with reverse. What did you do to get them working? I already have LED 921 bulbs in for reverse, and have no issues.
S
sealw98
detroit
I’m going to post the repair video tomorrow it was a pinning issue. Sorry they are VLAND aftermarket lights
PJs97Talon
Nashville, TN
3.0 and 6.7
It would be a lot better to just put the OEM 19+ HD tails in. Those VLAND lights will either be full of water or just fail internally in fairly short order.
S
sealw98
detroit
Probably true just couldn’t afford to do the complete 5th Gen setup right now. Was looking at 3x the amount when all said and done for OEM setup. Maybe I can do it later when it fails hopefully by then the parts will be plentiful and much more affordable
ric221
Waiting on a set of OEM taillights to come. Got the harness from retroshop hope all goes well with install. Will post pictures after install and any issues or errors that I get
BlownGP
Houston/Baton Rouge
Those look pretty good.
I guess Vland has the same reputation here as they do in the Mustang world. Vlad makes some clear led tails that a lot people get. Most are happy with them but some say they burn out or leak.
Lowrider357
