Jgress77
I was wondering if anyone has done this with a pre vvt engine? Is there anyway to run a vvt 6.4 in a non vvt 5.7 hemi truck while using my oem accessories? I've heard the pre vvt 5.7 timing cover won't fit a 6.4 vvt at all. Then I've heard it will if I run the black bird timing kit? Im wanting to build the engine with a twin turbo setup it will be running on a holley ecu so thats not a problem. I would like to run all my oem stuff so it still works with the oem ecu and fuse panel but the holley will control the engine.
