7" Wide Wheels and Narrower Tires
Blue Truck
Skagit County WA
No Spark Plugs
Probably in the minority here, but I'm a huge fan of narrower tires. Picked up some OE Ram 17" x 7" wheels recently (see attachment) and am thinking of running the 255/75-17" tires. The one bummer, is that most of these are P-rated instead of LT-rated. Trying to do this cheaply, so I've been looking at Jeep takeoffs for the tires.
Recently, I started seeing some 255/75-18's on Craigslist. Are there any 18" x 7" wheels available in the 5 on 139.7 pattern?
FWIW, I have the 5.9 and 3.55 gears. The tires on it now are 275/60-20, and it's a bit of a slug. The 255/75-17's bring the diameter down a little and the weight a lot. The 255/70-18's will be the same diameter overall, but the wheel/tire combo will be heavier than the 17's.
It would be cool if there were some 18" x 7" wheels that fit, then I could pick up some 18" tires that are heavier duty as take-offs from a 3/4 ton truck. If those aren't available, maybe I'll just plan on sticking with the 17's. Bridgestone Dueler Revo 2's do come LT-rated, so I'll hope I can find some of those. Am I worrying too much about getting LT-rated tires vs. P-rated? My 275/60-20's are only P-rated, and I see a lot of 1/2 ton trucks coming new with only P-rated tires.
Thoughts and recommendations? TIA.
dapepper9
Iowa/Nebraska Border
5.9L V8
I too am a fan of narrower tires. Better in the mud and snow.
I don't know about amy 18x7s off the top of my head BUT another option if you're not dead set on those 17s is 255/85/16.
Blue Truck
Blue Truck
Skagit County WA
No Spark Plugs
Thanks for the reply! Should have mentioned that I love the 255/85-16 tires, but they are rarely available used, and the new ones go for $250+ apiece. If some pop up, I would definitely grab them and go find some 16" wheels to fit. Another advantage of the newer take-offs is that I'd be getting tires with date codes within the last year or so. The last thing I want to do is buy some 7-year old tires from a rig that sat around.
dapepper9
5.9L V8
Looks like you have a first gen; I just sold my '92 W-250, Cummins, Getrag, Ext Cab. Cool rigs!
That's true didn't think of that.
Nah i have 2001 2nd gen lol
dapepper9
5.9L V8
I'm sure if you keep sound around local tire shops someone is bound to have some 255/75/17s takeoffs in LT rating. Craigslist be a good place to check too
Blue Truck
Blue Truck
Skagit County WA
No Spark Plugs
Caught that and was fixing it while you responded...D'ohhh! I must have been thinking of a whole bunch of things at the time and brain farted.
Good idea...thanks! How do you feel about the P-rated tires vs. the LT-rated tires? Since most of these are Jeep takeoffs, it's unusual to see LT tires for sale.
dapepper9
5.9L V8
They ride a little nicer. I had P245/75/16 Goodyear Wrangler Silent Armors on until August when i had a puncture. 36-40k miles on em still looked to have another 5-10k. They hauled half ton truck rated weight around just fine but if you're going to be doing heavy loads hold out for LTs
Blue Truck
Blue Truck
Skagit County WA
No Spark Plugs
Wouldn't you know it, but I found a great 33" tall tire, a Cooper Discoverer ST Maxx 255/80R-17 at Discount Tire for $208 each. The bummer is that I discovered how much of a dog my truck is for towing with the 3.55 gearing and 33" tires. Looks like I'm going to go with the 255/75R-17's to take the diameter down a little.
Arturo Rojas
