96 4x4 all wheel ABS hub swap
VietnamK9
Nineveh, IN
1996 extended cab, 4 - wheel abs, 4x4.
LF speed sensor bad. (96 speed sensors are rare, expensive. Manuf. rep. says no plan on manuf. more in Asia plant. I've done my homework on these sensors). Question: will a later model Hub/Bearing w/ABS work? Yes, I know an option is to scrap ABS and go w/aftermarket adjustable metering valve or pay up to $170 for the sensor if I can find it. Getting ready for new shaft u-joints and u/L ball joints while I'm at it. Thanks in advance if anyone knows if thers's a workaround. Thanks, Vietnam K9
Tumbleweed
Just wire all 4 speed sensor harnesses to one, single wheel sensor. No more hassles. Though your ABS won't work as well. Traction control, if you have it won't wor the same either.
With my '11 Wrangler I'd like to eliminate all the nannies!
ChloeBrooks
