99 5.9 magnum backfire through exhaust
Alexslo1k
Miami
As title states my ram is backfiring through the exhaust.
At one point it had a random misfire CEL I replaced the plugs wires and coil.
I used ngk copper plugs and autozone duralast wires.
I have not gotten a CEL light again but it still backfires "POPS" through the exhaust pretty bad.
Now this is only with no load on it, if I rev it up it will go through the RPM range perfect. I thought about the cat getting clogged so I started to drill some holes in it to allow it to breath I now has two 1 1/2" holes but it still pops although it feels like it has just a slight bit more power.
I have cleaned the IACV and throttle body.
What do you guys an girls think it can be?
Alex
Rodeoram93
Millsap tx
5.9l magnum
My 99 5.9 is having the same problem after I replaced one spark plug if u figure out what's wrong I would appreciate to know what it is... Thank you
Alexslo1k
Alexslo1k
Miami
My truck was purchased 3 weeks ago it did not do this during the test drive.
It happened after the purchase was completed roughly a block away from my house.
Alexslo1k
Alexslo1k
Miami
Anyone ??? Please I'm at a loss.
Also it does not have any CEL at the moment. yet it is still popping and low on power.
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
Does it do it when it's hot or does it matter?
jbmobbs
murfreesboro, tennessee
possibly spark plug wires are crossed or some **** like that. try a new coil pack,dizzy cap, rotor button, plugs, and wires......possibly injectors if ya got the cash lyin around
Alexslo1k
Alexslo1k
Miami
Update and not good. I pulled the new plugs I had installed and noticed cylinders 2 & 4 plugs look like they haven't even been started. I checked them for spark and they are good. And the injectors on those 2 cylinders are firing.
I am thinking that since they are right next to each other the cylinder head is bad maybe the valve seats have sunken. As it only pops on idle.
Might be selling the truck as I do not have time to keep messing with it.
Alexslo1k
Alexslo1k
Miami
Wooohooo Update figured out the firing order was off.
Now runs like a champ.
Alexslo1k
Alexslo1k
Miami
Hmm did someone say that? Lol
Yea apparently I kept crossing the wires for cylinders 2 and 4.
Not sure how I even missed that. I remember tracing them all the way back to the dizzy.
